Heater Fuse
Old May 28, 2011 | 11:41 AM
joeymmeezz's Avatar
Question Heater Fuse
Dose anyone know where the heater fuse is located, cause my heater isn't shutting off even when i push the switch to off
Old May 28, 2011 | 11:45 AM
xxxtreme22r's Avatar
Why not just pull a few till it goes off. Should be located behind the drivers side kick panel.
Old May 28, 2011 | 11:56 AM
joeymmeezz's Avatar
ok i found it thanks
I have one more question, when it is on it only works on kinda high and high dont really know why??
Old May 28, 2011 | 12:25 PM
smurphy's Avatar
The resistor bundle is failing. It's located on the blower housing.
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
Old May 28, 2011 | 12:51 PM
right I lost my heater low as well, that's the blower motor resistor. Not sure why it stays on all the time though. Might be the resistor is shorting itself out as well?
Old May 28, 2011 | 02:25 PM
jbtvt's Avatar
That would probably be the switch itself, shouldn't be any power at the resistor when the switch is off. Quick fix though, on both accounts.
Might I recommend avoiding Airtex Wells heater switches at all costs? Cheap plastic innards failed after <2 months on mine. Buy OEM one at a junkyard, much better off.
kawazx636
Oct 6, 2021 03:03 PM
woodyth
Sep 30, 2015 06:32 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
