head unit install questions
Old Aug 10, 2007 | 09:26 AM
yotafeind's Avatar
i am trying to install my deck but i cant seem to find the memory wire or the power wire that come out of the dash. does anyone know the color of these wires or have a good picture of them? it would be greatly appreciated. thanks
Old Aug 10, 2007 | 09:48 AM
OSU4Runner's Avatar
Did you purchase a harness to hook up your head unit to the truck harness? That should make it a painless install
Old Aug 10, 2007 | 10:35 AM
yotafeind's Avatar
no there is no factory harness. someone cut the wires. it was like that when i got the truck so i have to find everything first and then hook it up.
Old Aug 10, 2007 | 10:46 AM
4Crawler's Avatar
Run your own wires is the best answer. I did that on my '85, adding a fuse block at the battery and use a decicated power and ground wire back for radios, CBs, etc. Keeps the power (and sound) nice and clean. Otherwise, you can pull switched power off of the back of the cig. lighter and constant power off of the dome light circuit or similar.
Old Aug 10, 2007 | 11:08 AM
Embfixer's Avatar
I had a problem like this once. I went to the dealer and asked for a copy of the wireing manuel. They photo copied it for me and I was on my way..tl
Old Aug 10, 2007 | 11:33 AM
OSU4Runner's Avatar
Go to this website, enter your vehicle info and will give you wiring info
www.the12volt.com
Old Aug 10, 2007 | 08:33 PM
darth brian's Avatar
yellow is memory and red is power when i wired up my head unit
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
Coreyr384
Jul 10, 2015 11:13 AM
bryan34w
Jul 6, 2015 05:53 PM
