head unit install questions
i am trying to install my deck but i cant seem to find the memory wire or the power wire that come out of the dash. does anyone know the color of these wires or have a good picture of them? it would be greatly appreciated. thanks
Run your own wires is the best answer. I did that on my '85, adding a fuse block at the battery and use a decicated power and ground wire back for radios, CBs, etc. Keeps the power (and sound) nice and clean. Otherwise, you can pull switched power off of the back of the cig. lighter and constant power off of the dome light circuit or similar.
Go to this website, enter your vehicle info and will give you wiring info
www.the12volt.com
www.the12volt.com
