Got a hair puller her
Old Sep 15, 2019 | 04:31 PM
Mickey Gould's Avatar
Got a hair puller here. Running only when choked
85 pickup 22r will only run when choked. Fresh rebuild. When throttle is giving and choke is disengaged. Soon as it gets to idle it dies. Any info is greatly appreciated
Old Oct 1, 2019 | 12:12 PM
EFI85's Avatar
Idle too low or low speed jets clogged . Good luck
Old Oct 1, 2019 | 12:25 PM
akwheeler's Avatar
What EFI said, clogged jets or carb adjustment, it's not getting enough fuel at idle. When you apply the choke it richens up the mixture.
Old Oct 5, 2019 | 07:41 AM
13Swords's Avatar
5 Year Member
+3 on it starving for fuel & carb adjustments. Could be blocked idle passages/jet, blocked fuel filter, idle speed set too low, float set too low, etc. Could also be a fuel delivery problem. Hard to say with the limited info you gave.
Dayton
Oct 30, 2016 12:13 AM
SeattleCobra
Oct 17, 2015 03:26 PM
ydopen
Oct 3, 2010 02:05 PM
sr5yota84
Feb 24, 2009 04:07 PM
Dr.Trevorkian
Mar 28, 2008 05:24 PM
