gauges fuse burning
Old Oct 16, 2009 | 03:27 PM
HAWAII GUY's Avatar
gauges fuse burning
Howzit,everybody having trouble with my 95 toyota 4runner 3.0 my gauges fuse keep blowing at first it would blow every other day but it just kept on getting worse now as soon as i start it up it blows seems like it could be a ground but where do i start looking any help would be greatly appropriated much mahalo HAWAII GUY
Old Oct 19, 2009 | 11:21 PM
my-4x4's Avatar
wrong section
Old Oct 19, 2009 | 11:58 PM
muddpigg's Avatar
I had a short in the tail light harness the caused this with my '86.
Old Oct 20, 2009 | 12:08 AM
turboboost's Avatar
This sounds wierd, but my reverse light sensor (on the side of the transmission) was shorting out and blowing my fuse. I ended up pulling it out, and wiring the reverse lights to a toggle. That solved my problem.
Old Oct 20, 2009 | 06:01 AM
Team420's Avatar
I just had the same problem the other day... all I had to do was replace the negative battery cable. No more blown fuses.
Old Dec 27, 2009 | 09:07 PM
HAWAII GUY's Avatar
[QUOTE=HAWAII GUY;51254611]Howzit,everybody having trouble with my 95 toyota 4runner 3.0 my gauges fuse keep blowing at first it would blow every other day but it just kept on getting worse i tried doing diagnostic test but no help should i try pulling the dash
Old Jan 2, 2010 | 08:12 PM
Z's Confederate Toy's Avatar
I had the same problem with my 85 truck. There was a un insulated wire on the passenger side of the trans that kept hitting the driveshaft. Once I rewired it no more problem.
Old May 10, 2012 | 07:03 PM
KistCustoms's Avatar
Okay... so I'm having there same sort of issues and with my 90 4Runner
Old May 10, 2012 | 07:17 PM
its slightly worse but, as to the gauges fuse blowing and having un installed wires in that same location... my question is where is it you reconnected them to? I have bare wires but no other bare connections...
Old Feb 28, 2015 | 03:56 PM
sea dawg's Avatar
Which fuse drives the gauges on an '85 truck? Is it the same one as the tail lights?
Also, if you buy the plug in LED version of the 1157, does it require any special wiring/relay/resister or whatever??
Old Mar 10, 2015 | 01:36 AM
Oatmeal's Avatar
Had this same issue with my 85 and looking over the wiring diagram, seems the back up lights share the same fuse (labeled engine in fuse box)
Well turns out the wire rubbed on the transmission rib and wore through the insulation and shorted to ground fixed that and no more problems.
Not sure if your year truck is wired the same but if it is, I would check there.
Hans
Old Mar 10, 2015 | 06:02 AM
Terrys87's Avatar
The protective sleeve can also move just enough to let the wire rub the transmission and short it out. Usually with in a quarter of an inch of the plug on the top side was my experience. ( twice on two different trucks)
80Truck
Oct 12, 2025 07:25 PM
Gone Fission
Sep 4, 2015 12:18 PM
izzmee
Aug 17, 2015 10:20 AM
JHalcyonM
Aug 4, 2015 01:19 PM
rushw
Jul 18, 2015 01:46 PM
