Gas Tank removal / Propane instal
Old Jan 26, 2012 | 09:50 AM
84Horunner's Avatar
Finally ponied up and bought the propane kit from gotpropane.com (by the way those guys are super nice and very helpful)
My question is...How easy is the gas tank removal/drainage??(i have a full tank of gas) If anyone has done this i'd appreciate some tips. I plan on totally removing the gas tank and lines.
Thanks
Old Jan 26, 2012 | 09:56 AM
irab88's Avatar
1) watching
2) tank removal is easy
-drop the tank skid plate (3 bolts on each side)
-there's a drain plug. get ready to drain
-un-bolt the tank (3 bolts on each side)
-while dropping the tank, disconnect all the lines going to the top
-that's it
Old Jan 26, 2012 | 01:58 PM
Mr.Utah's Avatar
Much, much easier if the tank is nearly empty. There should be a drain plug on the bottom, be carefull.
Old Jan 26, 2012 | 02:29 PM
irab88's Avatar
^ yeah. what i meant to say was start draining on the second step.
Old Jan 26, 2012 | 05:43 PM
84Horunner's Avatar
Access the wires on top of the tank through the hole in the floor beneath the seat?
Old Jan 27, 2012 | 10:00 AM
stpshane's Avatar
hi everybody just joined today first post i want to convert a 2005 tacoma v6 to propane/gas do you guys know anybody that has done one thanks in advance,Shane
Old Jan 27, 2012 | 05:45 PM
85TurboRunner's Avatar
I usually don't bother draining the gas when removing the tank. Always gets everywhere.
Use a floor jack and some straps under the tank across the frame rails and lower it down.
I find it easier to pour the gas out of the fill spout into a canister after its already out of the truck.
No smelling like gas afterwards.
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
redneck17
Jul 17, 2015 07:44 PM
nick b
Jul 11, 2015 04:38 AM
crashburnoveride
Jul 10, 2015 06:39 AM
