fuel injection problems
Old Apr 28, 2015 | 10:32 AM
ej_jenkins's Avatar
I have an 85 truck 22re and can't figure out what's wrong ... I'm not getting any fuel threw my injectors but I'm getting fuel to the fuel rail and when I put a test light to any of the injector plugs there is constant power should it be pulsating
Old Apr 28, 2015 | 01:17 PM
Terrys87's Avatar
I get 8-12 pulses https://www.yotatech.com/forums/f116...t-22re-270857/ when using this LED. If you are getting pulses, it could be the crimps are corroded. The computer can be sending the signal but the crimps can keep the signal from passing.
Other things I check https://www.yotatech.com/forums/f199...l#post51897320
Another thing I would check for is if the injectors are clogged.
Old Apr 28, 2015 | 02:04 PM
wyoming9's Avatar
Red face
I am pretty sure a test light won`t work if that is what you meant. .
What are they called Noid lights for testing if the injectors are firing like they should.
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
