first truck!
Old Oct 16, 2012 | 09:31 AM
missyota84's Avatar
first truck!
recently bought my first truck 84 ext cab sr5 5sp
my boyfriend bought this truck for 800 bucks stock with bad paint and a blown out rear end. the previous owner had a detroit truetrac installed along with new ring and pinion but a seal broke leaking oil and blowing the ring and pinion, fixed that put a lift on it and painted it then i bought it from him. i bought it for 1100 which was what he had into it and love the truck
(truck now has pink stripes)
now the truck has a brake problem, the brakes are really soft but they will skid if you push them all the way down, tried bleeding them no change. the whole rear end is rebuilt new lines wheel cylinders bads ect.. when you kink the rear brake line the pedal gets pressure there are no leaks in the rear, any ideas?
my boyfriend (runs-on-4) said i have to figure this one out by myself. tried searching but im quite sure what to search for
thanks!
Old Oct 16, 2012 | 10:05 AM
runs-on-4's Avatar
whoever painted that truck sure did a good job!
Old Oct 16, 2012 | 10:18 AM
irab88's Avatar
re: brake problem
you haven't bled them enough. when i put in my rear locker, i thought i'd bled the brakes good enough. then i hop in and the pedal is still soft (like what you describe). i took another 10 mins to bleed them, and sure enough, there was a lot more air still trapped. topped it off and drove away with no more issues thus far.
Old Oct 16, 2012 | 11:15 AM
REDYOTA's Avatar
excellent truck, lucky guy, or lucky girl cant tell maybe both of you are lucky.
Old Oct 16, 2012 | 12:39 PM
rokblok's Avatar
Are the rear brakes adjusted so that they barely drag the drums? And is the LSPV bled and adjusted properly?
Old Oct 28, 2012 | 08:18 PM
missyota84's Avatar
finally got around to bleeding them again, went threw a quart. still soft, tired adjusting/bleeding the lspv still no luck, probably going to take it to the shop.
Old Oct 29, 2012 | 07:04 AM
coreyzupka's Avatar
Could the brake problem be the anti skid valve, or proportioning valve, its called something else on these trucks, but I know that could cause the skidding if its not working right.
Old Oct 29, 2012 | 08:02 AM
Crtzlow's Avatar
Air in the master cylinder maybe or a bad master?
Old Oct 29, 2012 | 08:56 AM
donomite49's Avatar
maybe you can find a new boyfriend that will help you with
your truck. yotatech want ad...lol.
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
thelifeadventure
Jul 2, 2015 03:09 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
