First Gen 4runner Rear Window Regulator Malfunction
Old Jan 4, 2009 | 06:29 PM
GodwinAustin's Avatar
I know there is a ton of info out there on this. But most applies to the electrical system.
I finally got my rear window working, but when the window goes down, it goes down crooked - and I need to get out - straighten the glass a couple times on the way down. It goes up fine.
But from what I have read this appears to be a problem with stripped teeth on the rear window regulator.
Is there a writeup on how to fix this regulator issue? Can I repair the side that is slipping or will I have to replace the whole unit? Thanks.
Old Jan 7, 2009 | 05:22 PM
DaHos's Avatar
There is a track on the lower portion of the gate window, I bet the "arms/rollers" jumped. easy view just pull the carpet panel..........
Old Jan 10, 2009 | 07:09 AM
timmytoyota's Avatar
If the teeth were stipped on the regulator,the window would not go up or down,it would stop in the same place each time.I agree with DaHos that the window jumped out of the track.
Old Apr 13, 2011 | 02:25 PM
sac85-1stgen's Avatar
My regulator arms are way off from each other, any ideal were i can get a new unit?
Old Apr 13, 2011 | 02:41 PM
kiyobrown's Avatar
Welcome to YT. If you don't have the same problem, you can start a new thread...... If you searched first and yielded no results.
Have you pulled the regulator out? Download an FSM or a chiltons. They have directions on how to get it out. If the PO replaced the motor in there, they could have not aligned the teeth properly, making your arms diff height. Pull it out of there and check it before you pony up for a new one. Craigslist and eBay are places to find used ones, plus various parts places like Nix99
warrenjcarlson
Jul 22, 2016 11:47 AM
scottt80
Jul 1, 2015 12:13 PM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
