Finished Painting.....
Old Aug 25, 2010 | 06:48 AM
richf's Avatar
Went from this
Installed my toyotafiberglass.com drivers side rear quarter. The panel fit great, I also used 3M 5200 to attach it to the truck. It was cheaper than the $500.00 tube of glue they wanted at the paint store. I think the 5200 was $14.00 dollars a tube. I used Parker Coatings sand tan duck boat paint with a harbor freight purple spray gun. It turned out really good, no runs everything is even.
I'm looking for input on what the color for the top (black or tan) and mirrors the towing style mirrors (black or tan)
Old Aug 25, 2010 | 07:21 AM
pwd's Avatar
pwd
I think it would look good with just a black top. Paint job looks great, glad to see you went fiberglass so it won't rust.
Old Aug 25, 2010 | 10:12 AM
myyota's Avatar
Was it fairly easy to install the rear quarter panel ?, the right rear quarter panel on my 4Runner is damaged and im not sure if it can be repaired or if it needs to be replaced.
Old Aug 25, 2010 | 10:22 AM
DirtyOregonKid's Avatar
you should do the top, roll bar and mirrors OD green!
Old Aug 25, 2010 | 11:16 AM
richf's Avatar
Yes the rear quarter was extremely easy to repair with the panel from toyotafiberglass. I chose to replace mine with the fiberglass panel because I had major rust around the bottom of the wheel well and the top rail. The good thing about the panel is all you have to do is attach it with the adhesive do a little body filler, sand, prime and paint. I wish I did both sides with the fiberglass panel, but I didn't need it. If you do it use the 3m 5200, it's a hell of a lot cheaper and if it's good enough for boat makers to use it on fiberglass boats it's got to be good enough for the toyota.
Old Aug 25, 2010 | 11:18 AM
richf's Avatar
I thought about doing that. Maybe I can get someone to photo shop it for me.
Old Aug 25, 2010 | 11:59 AM
Ardent's Avatar
Tan FTW! Looks great. My vote is for black topper.
Old Aug 25, 2010 | 12:22 PM
myyota's Avatar
When you install the fiberglass panel, how do you seal the inner fender to the new bed side ?.
Old Aug 25, 2010 | 12:23 PM
camo31_10.50's Avatar
hm, i'd like to see the OD green top, roll bar and such.
but i think the top being tan would look great
Old Aug 25, 2010 | 01:08 PM
richf's Avatar
You apply the adhesive to all contact areas. The inner fender well touches the panel, so it gets sealed by the adhesive. Behind the panel I also applied seam sealer for extra security. When you are finished with the panel everything is sealed up. You do have to apply the adhesive to bare metal which I hope doesn't create moisture some how and rot out over the next couple years. Time will tell.
Old Aug 25, 2010 | 04:13 PM
slacker's Avatar
looks great Rich .. I tried to "sell" you on both panels , but 'sall good
not sure about your "glue" choice though , that product remains flexable , much like a calking .. I guess only time will tell
P/S
your clips are on there way to you
Old Aug 26, 2010 | 02:28 PM
richf's Avatar
Thanks. I also read that about the 3m 5200. I hope it doesn't fail on me.
Old Aug 26, 2010 | 05:40 PM
Dannyboy0818's Avatar
Looking good.. I like the color
Old Aug 27, 2010 | 02:05 PM
richf's Avatar
thanks
Old Aug 27, 2010 | 02:24 PM
ChefYota4x4's Avatar
Looks great! My buddy has that color on an 85 Long bed 4x4... He has his soft 8's and top in a dark brown... looks great!
Old Aug 27, 2010 | 03:05 PM
Dingman's Avatar
Black topper. All that tan needs broken up.
Old Aug 27, 2010 | 03:45 PM
richf's Avatar
Anyone have a good vendor for brand new weather stripping? I was attempting to put stuff back together today and all the stuff I took off is junk. Mostly the stuff for the doors and windows is what I'm looking for.
Old Aug 27, 2010 | 04:21 PM
phildelfino's Avatar
I'd like to know if anyone besides the dealer sells weather stripping too. I don't know if the dealer sells it, never checked.
Old Aug 27, 2010 | 05:18 PM
I replaced both my doors stripping, all the way around, for pretty cheap, through my local yard. Just had to go through everything they had, and found a Calif. car with low miles, great rubber, .... worked out great..... and MUCH cheaper.
Old Aug 27, 2010 | 06:09 PM
richf's Avatar
I found the seal that goes around the door online for $65 you get both left and right side but not the seals that go inside the door for the window or the outer seal for the window those are the two that I'm most concerned with. I hate old anything!!
