Engine Swap, Now No Charge?
Old May 23, 2009 | 07:27 AM
JasonWin's Avatar
As some of you may know the engine in my 85 went on me. Since then I found a 22r and swapped over all the accessories (so it's a 22RE now ) and it's back in the truck and runs (not that well yet but that's another story) anyway ever since I put the new motor in I haven't been able to get the alternator to charge the battery. It was working fine before I swapped the motors but nothing. I've got a parts truck with a good alternator but if that's not the problem there's no since in swapping them right now. I already checked all the connections on the alternator itself and still no charge. Is there something else I should be checking?
Any suggestions would be appreciated.
Old May 23, 2009 | 07:56 AM
4Crawler's Avatar
Have you checked all the grounds from the engine to the frame, body and back to the battery "-" terminal?
Old May 23, 2009 | 08:08 PM
85RunnerSR5's Avatar
You may have a bad ground to the frame. Was your truck originally a carb version and converted to EFI?
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
