86 injectors wont pulse
Old May 22, 2009 | 01:01 PM
crw's Avatar
crw
Question 86 injectors wont pulse
I have an 86 4runner that blew a head gasket and sat for about 6 years. I just put on a new head and gasket set, new fuel filter, new fuel pump, new injectors, and drained the tank and put in new gas. It will crank only if I spray starter fluid into the intake and then it dies once the starter fluid is burned. All the injector connectors show 12 v on each wire. I put a noid tester on the connectors and they are not pulsing when I turn the engine over. I jumped the diagnostic connector and get codes 7 and 11. Any help on how to figure out why there is no injector pulse would be greatly appreciated.
Thanks
CRW
Old May 24, 2009 | 08:48 AM
Wardamneagle's Avatar
The wiring harnesses are notorios for having breaks at the connections. You might start testing continuity at the injector and work your way backwards. They fire two at a time so it's a bit unusual that none of them will pulse. Of course I'm not sure if the engine will run on just 2 cylinders; I'm guessing not.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
themightykhoner
Sep 18, 2015 02:28 AM
Kytowboater
Sep 17, 2015 11:17 AM
EatChipsNow
Sep 9, 2015 01:25 AM
