EGR valve gasket?
Old Jan 21, 2012 | 08:31 AM
Jmann40's Avatar
EGR valve gasket?
So I just received my new EGR valve that I purchased from Toyota to solve my surging problem I have been diagnosing for months. Should I have a gasket for this? When I spoke to Toyota, there is the one gasket with two bolts, but they told me there was not one listed. (for the triangle shaped piece that attaches to the block) I did see one on the Napa website and a few others and I am not sure that this triangle shaped gasket is necessary or is year specific. Any thoughts?
Old Jan 21, 2012 | 08:36 AM
mudslinger83's Avatar
is that gasket not built on to your intake gasket
Old Jan 21, 2012 | 08:56 AM
Philbert's Avatar
i just cleaned my egr recently for smog prposes. there is only the one gasket with two bolts that you need. nothing for the block. i was also confused
Old Jan 21, 2012 | 03:52 PM
ephwang's Avatar
I know if you purchase the Fram intake gasket for the 1985 22RE, the EGR portion is part of it. It can be separated from the intake portion if you just need the EGR gasket.
Old Jan 21, 2012 | 09:57 PM
Jmann40's Avatar
Sounds like I don't need it. Thank you all for your input. I am going to bolt it on my next day off. I hope it solves my problems.
Old Jan 22, 2012 | 11:42 PM
854x4's Avatar
On a 22re there are two egr gaskets one on the back of the plenum with two bolts and one on the lower intake with one nut and two bolts. The plenum egr gasket is sold by its self but the other one with three holes is part of the lower intake gasket but can be cut off and used by its self without replacing the whole lower intake gasket. You need a gasket do not install it without one.
Old Jan 23, 2012 | 06:08 AM
snobdds's Avatar
This is the correct information. The gasket is part of the intake mainifold gasket. You do need a gasket...or you will be chasing down a vaccume leak...
Old Jan 23, 2012 | 07:52 AM
Jmann40's Avatar
Yes, now I see the gasket and it makes sense. Thanks again for the help.
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
87blyota
Jul 10, 2015 04:31 AM
