Ebay lift kit for light trail use. Opinions
Old Aug 14, 2007 | 09:24 PM
gotboostedvr6's Avatar
here is the kit :
http://cgi.ebay.com/ebaymotors/79-85...ayphotohosting
This kit contains:
+ (2) new replacement front leaf spring packs w/ bushings
+ Front U-bolt kit
+ Sway bar sleeves and bolts
+ Brake line bracket
+ Rear block and u-bolt kit
Rear springs like the ones pictured are available for an additional $130 and NO additional shipping.
+ (4) premium grade 8000 series shocks
+ All necessary hardware and brackets
+ Instructions
what do you guys think>?
Old Aug 14, 2007 | 09:42 PM
olharleyman's Avatar
Don't risk it get a known brand and do it right the first time and have no problems on the trail. Have a cheep set up and you will be paying way more in the long run for a bad decision.
Old Aug 15, 2007 | 04:06 AM
85TurboRunner's Avatar
Well it looks to be a rough country lift which is right up there with pro-comp and trail master. If you just want a cheap lift then go for it, but dont expect a smooth ride or much flex.
Old Aug 16, 2007 | 09:39 AM
corvettelvr73's Avatar
I was thinking about the same lift. I just want it for looks and light use. I dont know what makes it not so good. I think it will be fine
Old Aug 16, 2007 | 03:42 PM
Doc279's Avatar
That kit is sold in my home town. I don't have one but I've heard good things from locals that have used it. Buy the rear springs - don't use the blocks and you should be fine.
I am considering the same kit - I'm just saving money at the moment.
My front springs have a negative arch and I will replace them before wheeling again. My 85 is not my daily driver though !
I finally reached a point in my life that I have several TOYS !!!!!!!
50 sucks though !
Old Aug 16, 2007 | 05:19 PM
dropzone's Avatar
Fossilized
For light trail use it should be fine and get you set up to clear 32's or 33's.
Definitely spend the extra and get the rear springs. Sure it would be great to 'do it right' the first time and drop $1500 on the Marlin or All-Pro kits. But to get you started it will work and get you the bug. See how it works and down the road maybe decide to invest in a better kit.
One recommendation though would be to look at extended brake lines (F&R). When I bought my '81 the brake lines were about stretched out. $75 order to Trail gear and a few days later I had that part fixed...Good luck!
Old Aug 16, 2007 | 07:20 PM
thewjsand's Avatar
The kit without the blocks is 399.99...
http://cgi.ebay.com/ebaymotors/79-85...2800QQtcZphoto
so there are two different ones... you should get the 3" one and let us all know what you think The company sells allot of other lifts and looks legit and Ruff country is reputable brand.
I don't know i'm considering that lift also since my 85' will most likely only used lift for trail excursions and there aren't any mt's in MN...
Lets us know what you decide!
Old Aug 16, 2007 | 08:51 PM
im going to order the kit with springs front and rear ill keep you guys updated
Old Aug 16, 2007 | 09:32 PM
Henrythewound's Avatar
You get what you pay for. If that's all you are expecting then there isn't a problem. Personally I wouldn't do it, I just ordered a SS#7 kit (don't know if they even offer kits for 1st gen runners) for myself. I have bought cheap options on various things before and always ended up doing it right later on down the road, thereby costing me more $$ than if I had saved longer and did it right the 1st time. Just my opinion
Old Nov 20, 2007 | 06:42 PM
Bskey's Avatar
I have this kit installed and it is fine. Not a ton of flex, but a better ride than my stock seized up suspension. I got the 1.5 inch greasable shackles too as you may not be able to reuse your old ones, and definitely needed the extended brake lines.
Old Mar 21, 2008 | 01:27 PM
anyone have any updates?
Old Mar 30, 2008 | 08:12 AM
kingbrian's Avatar
delete this..
Old Mar 30, 2008 | 08:13 AM
kingbrian's Avatar
i dunno about them but i went with the downey 3 inch kit and its incredible over stock... i got bit by the travel bug so im itchin for more travel now.. heres the stock before and the after
completely flexed
and now with the downey three inch and prerunner AAL
and i can beat the hell out of it and still drive it home.... oh and it was only 368 bucks shipped to me!!
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
