Dual Tcases or 4.7 gears?
Old Aug 18, 2013 | 04:24 AM
dzldust's Avatar
What does a single case vs dual case have to do with twisting a shaft? A shaft can be twisted in a stock truck if you come down on a rock wrong
Old Aug 18, 2013 | 06:40 AM
SHINE RUNNER's Avatar
well if your using the extra thin wall stock shafts they are going to twist. I always use schedule 40 tubing front and rear so does a lot of people here. I have twisted both before I got duals. also as for smoking the gears in your tcase"running high rpm" your going to be using 3rd and 4th a lot or using 4h 1st and burn a clutch.as compared to duals you got more gear options like 2wd low or 4h low. hey you got to start some where good luck
Old Aug 18, 2013 | 08:13 AM
dzldust's Avatar
Thanks
priest16
15
Aug 6, 2015 07:43 AM
yourrealdad
Jul 29, 2015 11:08 AM
SMOD
Jul 23, 2015 10:29 PM
crashburnoveride
Jul 10, 2015 06:39 AM
