Differential bearing questions.
Old Dec 12, 2011 | 07:52 AM
2003mikem's Avatar
I am putting 5.29 in my 1985 4runner.
I am replacing all the bearings.
Question is what is a good bearing?
I see them form 18.00 to 60.00 +
I want a good bearing but don’t know what to buy ?
Timken
National
ETC….
I have the bearings for the pinion that came with the install kits.
Old Dec 12, 2011 | 07:59 AM
waskillywabbit's Avatar
Use the ones that came in the install kits. Key is setup.
:wabbit2:
Old Dec 12, 2011 | 08:18 AM
2003mikem's Avatar
i only have the pinion beatings. no carrier beaings
Old Dec 12, 2011 | 08:21 AM
OEM then.
:wabbit2:
Old Dec 12, 2011 | 08:28 AM
2003mikem's Avatar
dealer OEM ?
Old Dec 12, 2011 | 06:36 PM
2003mikem's Avatar
Can anyone give me the timken part numbers for the bearing and races?
The local part stores are dumb as a stump here..
Old Dec 13, 2011 | 03:49 AM
rokblok's Avatar
Koyo or Timken in my opinion...
Did you get a master install kit for your gear set-up?
They will come with everything for the rear diff except axle seals and axle/wheel bearings... so essentially everything for the 3rd member.
Old Dec 13, 2011 | 05:23 AM
2003mikem's Avatar
No carrier bearings just pinion bearings.
Old Dec 13, 2011 | 07:06 AM
dropzone's Avatar
Fossilized
replace all the bearings...master install kit would have saved you some head aches...
and when you removed the carrier bearings you marked them left and right, right?
Old Dec 13, 2011 | 07:16 AM
2003mikem's Avatar
I am setting up two carriers to put in my 1985 4runner ” not me someone who does this for a living “
Pull out the carries with 4.10s and put in the a carries I am setting up with 5.29 so I can do a simple swap” not pull out and build and put back in. just swap them out.
I have 2 new 5.29 ring and pinions.
2 minor install kits “ pinion bearings ,shims, crush collars”
I do have 2 used carriers.
I do not want to reuse the carrier bearings.
The local parts stores are full of dumb people.
Unless they can look it up on their electric catalog they can’t find it. nor do they have a clue how to use a book.
I do not want to buy a master install kit.
I am looking for OEM quality or better.
I would like Timken or OEM.
I have looked online and see several numbers just looking for confirmation.
Old Dec 13, 2011 | 08:32 AM
rokblok's Avatar
I thought all the 4 cyl 8" Toy carriers were the same. For certain year ranges anyway. What are the online sites and what are they listing as options?
Old Dec 13, 2011 | 08:58 AM
2003mikem's Avatar
All store around here are trying to sell me national bearing.
Auto zone wants to sell me a kit for the hole axle 180.00 plus per axle.
I have found Timken number while searching .
Carrier bearing # 17887
Race # 17831
Also Timken carrier # lmk603049
Timken race # lmk603014
This is what I am try to figure out .
Old Dec 13, 2011 | 11:54 AM
Sensei's Avatar
You can be a purist or a realist. I've used National bearings, plus all the others, for years without issue.
Pinion bearings need to be set up correctly or failure will occur, regardless of the name on the bearing box. Incorrect preload, sloppy installation, contaminated surfaces is what kills bearings.
Old Dec 13, 2011 | 09:15 PM
3linked84's Avatar
Odd there is no carrier bearings. Try randys ring and pinion and get the yukon one's. I work at a dealer and put 2 together with factory bearings and races, and then put two together with a yukon kit and they were the same make. I cant remember the brand though. You get what you pay for.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
YotaPagota
Sep 20, 2015 06:24 PM
Adam Edgar
Sep 20, 2015 03:24 AM
scheuvront1993
Sep 17, 2015 06:17 PM
