Crankshaft Bolt is Seized
Old Dec 23, 2011 | 08:40 AM
B4Runner's Avatar
My timing belt broke. Everything that needs to be torn of the front of the engine is off except for the crankshaft pully and the plastic piece behind it.
My problem is that the bolt is horribly seized. Even with having been soaking it with PB Blaster for the past few days, an impact gun isn't even taking budging the bolt.
The suggestion after that was to set a breaker bar against the frame and crank the engine. Did so. The bolt was so tight, the starter couldn't even turn the bolt. Eventually, the starter broke the (19mm) socket.
I know need advice on what else I can do. I was told that the bolt is robably so thight because of the truck is an off-roader and all the dirt, dust, and water has seeped in there.
Thanks to all that can help me out.
Old Dec 23, 2011 | 09:10 AM
xxxtreme22r's Avatar
that starter broke a 19mm 1/2" impact socket?
Old Dec 23, 2011 | 10:27 AM
snobdds's Avatar
Make a relief cut on the washer part of the bolt. Just a slit with a cut off wheel will work too. Make sure you don't nick or damage the pulley in anyway. Protect it with scrap metal or something.
It should come right off, but you will need a new bolt - $10 bucks
Old Dec 23, 2011 | 10:32 AM
dropzone's Avatar
Fossilized
Leverage...slide a piece of pipe over your breaker bar..
Old Dec 23, 2011 | 10:49 AM
kev's Avatar
kev
like above... a pipe on the breaker bar. Apply leverage and also strike the breaker-bar end with a bfhammer. this has worked for me on the exact bolt! I hope this helps
Old Dec 24, 2011 | 04:43 PM
SoCal4Running's Avatar
Depending on the impact it may be more noise than torque!
Beg, borrow, rent or buy a Ingersoll Rand gun and shell come loose no problemo
Corvoid
Sep 14, 2015 10:10 AM
Pocoyota
Sep 8, 2015 02:41 PM
Jwp1
Sep 6, 2015 11:03 AM
eggens
Sep 5, 2015 12:16 AM
seab1209
Sep 3, 2015 05:41 PM
