Which clutch for a 2wd 85
I have a 2wd 85 pickup with a 4 speed manual trans. and the clutch is going out. the truck is stock except for a weber 32/36. LCE has a great deal on their clutch kits right now. anywhere else you guys recommend?
Marlins clutches are great products. I have an '84 4wd, and I of the 1200lb set up. Excellent fit and finish. I would think with your mostly stock 2wd, the 900lb unit would be fine. Give them a ring. And good luck!
May-39
Sep 6, 2015 01:05 PM
