cleaning throttle body and other intake parts
Old Dec 16, 2009 | 10:28 PM
nomiss05's Avatar
im going through my engine b4 i finish my swap to paint it and clean it and make sure all the internals are fine. anyone have any suggestions for cleaning the inside of the trottle body and the other 2 peices that have build up in them?
Old Dec 17, 2009 | 06:45 PM
myyota's Avatar
The best way to clean the intake and throttle body is to remove it and take it all a part so you can get into it easier. It took about 5 cans of carb cleaner when i did mine.
Old Dec 18, 2009 | 06:36 AM
nomiss05's Avatar
i have it all apart right now. do you just scrub it out or what? i just dont want to hurt the inside.
Old Dec 18, 2009 | 07:25 AM
snobdds's Avatar
Make sure you use throttle body cleaner specifically...So it won't affect the TPS.
Old Dec 18, 2009 | 07:28 AM
badattitude's Avatar
I'd use the throttle body cleaner. Let it soak for a couple minitues then it should wipe off easy with a rag and cotton balls.
Old Dec 18, 2009 | 07:31 AM
RustBucket's Avatar
Toyota's FSM recommends using carb cleaner (probably just as good as TB cleaner) and removing the TPS before cleaning the throttle body. Just put on a couple of precise matchmarks and you'll be good to go.
Use a stiff plastic brush and just go to town with it. You won't damage the cast aluminum if you use plastic.
Old Dec 18, 2009 | 06:21 PM
Blacksmith04's Avatar
Smile
I put mine in a parts washer and scrubed it for about 2hrs. This only got a little bit out. Came home and tried carb cleaner and an old tooth brush. All that did was move the gunk around inside the intake parts. Then I took all the parts to the car wash and hit it with high pressure soap. This did the trick and blasted all the crap out for a buck fifty. It was clean as new. Just wish I had read about removing the tps first.
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
