Cheap transmission fluid alternative
Old Dec 7, 2013 | 07:28 PM
hitsua's Avatar
I just had my W56 rebuilt and I figured I would flush it after a few hundred miles or so, and I don't want to waste a jug of redline. I searched around and had a hard time finding a semi-decent cheap fluid. Any thoughts?
Old Dec 7, 2013 | 07:49 PM
JasonYota's Avatar
You just had your trans rebuilt and you want to put cheap fluid in it?
I would change the fluid after a couple hundred miles and then again after a couple hundred miles, then change per the service manual.
Good brand fluid will clean it out better, it won't be a waste.
I took my trans apart and cleaned everything I could, put it back and put Amsoil in, less than 20 miles I drained it (had to pull trans again) and it was black. Cleaned it pretty good.
Old Dec 7, 2013 | 07:55 PM
hitsua's Avatar
I planned to put Redline in it after I flushed it, I just didn't want to use expensive fluid that I am going to flush soon after. I'm not talking like bottom barrel, just not $60/gallon.
Old Dec 7, 2013 | 08:00 PM
JasonYota's Avatar
I'd still spend the money now on it. And I'm cheap. You just had it rebuilt why not treat it good?
Old Dec 7, 2013 | 08:01 PM
hitsua's Avatar
Alright that is good advice. It had 320k miles on it I guess I should start off on a good foot.
smthwsn357
May 1, 2024 07:28 AM
Poppie51
Aug 2, 2015 11:29 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
