Carburetors & steep angles
Old Sep 15, 2008 | 12:56 AM
XtraSlow_XtraCab's Avatar
Question Carburetors & steep angles
Alright so I'm reading up on EFI conversions and all that good stuff and I keep seeing "carbs suck for offroading because they sputter and stall at steep angles".
I'm not a professional rock crawler or anything, but I've had my experiences and have never had this problem. The only time this may happen is if I push in the clutch and let the engine idle through a whoop section. As far as inclines go... never been a problem.
Is my AAP system working more than it should or something? My choke doesn't work if that be the case. Starting her up in January sucks big time.
(pump pump, starter whine, sputter, stall, pump, pump, pump...)
Old Sep 15, 2008 | 12:31 PM
85toy's Avatar
maybe you need to go up steeper hills? mine stalls on hills all the time when offroading.
Old Sep 15, 2008 | 01:23 PM
blackspyder's Avatar
use a side bowl or off road carb if you're stalling ( what happens is the front bowl will drain back into the carb or rear bowl and stall or the rear bowl will not supply fuel to the carb.
Old Sep 15, 2008 | 01:58 PM
drew303's Avatar
theres only one bowl on our carbs... its in front. On inclines it just floods.
I was planning on doing an EFI conversion (got most of the parts right now) but decided not to since I've just learned to live with it, stay on the skinny enough it won't die, just burn rich.
Old Sep 15, 2008 | 03:12 PM
85toy's Avatar
yyep thats what i learned
live4soccer7
May 11, 2016 06:52 PM
the_supernerd
Oct 1, 2015 09:20 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
ErikZ1220
Sep 10, 2015 04:53 AM
