Can’t get the idle speed down!
Old Aug 29, 2025 | 08:47 AM
burntcloth's Avatar
Hi y’all,
Can’t get my 85 22r idle down. Original Aisin carb.
It has no fast idle at start, starts around 750-800 and as it warms up (choke plate full open), it rises up to 1150-1250rpm and stays there. I’ve rebuilt the carburetor and replaced the vacuum hoses and I’ve backed the idle adjust screw out to the point where the cam doesn’t make contact with it at idle. I’ve sprayed carb cleaner and propane around looking for a leak somewhere and got nothing.
Any other recommendations?
thanks
Old Aug 30, 2025 | 05:10 PM
prcnctoyo's Avatar
Do you have initial timing set properly? Are you adjusting the right screw for idle speed? Don't be offended. Link below to download FSM if you need it.
https://web.archive.org/web/20110102...ttora.com/FSM/
Old Aug 30, 2025 | 06:42 PM
burntcloth's Avatar
Yes, thanks, I should have mentioned that the timing is good, and yes, that’s the idle screw I’m looking at that isn’t touching anything (there’s a gap at the end of the screw, which makes me think something is keeping it rev’d up…
Old Aug 31, 2025 | 01:43 PM
prcnctoyo's Avatar
Double check the linkage. When I rebuilt my carb I had to dismantle the linkage. Pics from a spare carb I have on hand.
Old Sep 1, 2025 | 11:25 AM
burntcloth's Avatar
Originally Posted by prcnctoyo;[url=tel:52502452
52502452[/url]]Double check the linkage. When I rebuilt my carb I had to dismantle the linkage. Pics from a spare carb I have on hand.
Thanks for the pictures. Everything looks right where it should be. Going to make sure all hoses are going where they’re supposed to next
Old Sep 6, 2025 | 10:03 AM
burntcloth's Avatar
Choke breaker clue (edit: choke opener)
When I unplug the vacuum from the choke breaker opener diaphragm, the fast idle cam stays up and the engine idles high as it should, and a blip of the throttle kicks the cam down as it should. So I’m guessing there’s too much or too early of vacuum for some reason? Or the diaphragm spring is weak?
Old Sep 7, 2025 | 09:09 AM
prcnctoyo's Avatar
Test the choke breaker, p. EC-62. It's job is to "...slightly open the choke valve to prevent a too rich mixture after firing when the choke is closed." Did you open the choke breaker and replace the diaphram with the rod that extends in to the choke? e clip back?
The choke opener is the one that holds the choke valve open and releases the fast idle cam. Test in FSM on EC-63. The choke opener isn't opened during a rebuild. So I don't know what's inside it.
Old Sep 7, 2025 | 09:49 AM
burntcloth's Avatar
Originally Posted by prcnctoyo;[url=tel:52502512
52502512]Test the choke breaker, p. EC-62. It's job is to "...slightly open the choke valve to prevent a too rich mixture after firing when the choke is closed." Did you open the choke breaker and replace the diaphram with the rod that extends in to the choke? e clip back?
Oops, sorry, I got that wrong. It’s the choke opener that I disconnected to get the fast idle cam to stay at startup. Good intuition on your second guess…maybe it’s BVSV related.
Okay, got the BVSV (or the BVSV #1 ?), the three-ported reddish-brown thermo valve on the intake manifold. Aisin 25810-27010 written on the side. I did the test per the FSM EC-60 and I couldn't get any air to blow through the top port until I put compressed air into it and that blew it loose. Problem is that when I blow on the valve hot, air comes out the top, but if I plug the top port, it (weakly) comes out the bottom port. Same problem (but opposite) for when it is cold. Which makes me think the valve is shot. That part isn't available anywhere new, apparently.
Old Oct 22, 2025 | 03:34 PM
burntcloth's Avatar
Finally fixed it
Okay! Got the idle down. Turns out it was just the throttle cable being too tight. Ugh. Worst part was that I had checked for that already, even disconnecting the cable while the engine was idling. I can only assume the throttle arm hung up somehow on that test. Passed smog!
Old Oct 25, 2025 | 06:19 AM
prcnctoyo's Avatar
Glad you got it fixed and smog test passed! I don't have to have my truck inspected any longer. I'm in North Carolina. Thanks for posting the fix!
Davids81
Jan 8, 2024 06:13 AM
Blue8seven
Jul 15, 2014 04:46 PM
drinkbeerdaily
Oct 31, 2013 08:13 AM
83
Apr 21, 2009 11:23 AM
rods
Mar 17, 2008 10:15 PM
