Can I run 32" tires?
Old Sep 24, 2007 | 03:23 PM
85toy's Avatar
I know this is a noob question and has beeen asked before. but i searched for this and i could not find an answer. i found a good deal on a set of tires/rims and i want to know if i can fit em on my truck. here are some pics of the truck. the tires on the truck right now are 30x9.50, the ones i found are 32x11.50.
Attached Thumbnails Can I run 32" tires?-earthspin-comp.-070.jpg   Can I run 32" tires?-earthspin-comp.-069.jpg
Old Sep 24, 2007 | 04:19 PM
88wildrunner's Avatar
id say you could fit them, looks like you have plenty of room in those fenders, they just might rub a little when wheeling.
Old Sep 24, 2007 | 04:26 PM
86blue4runner's Avatar
yea id go with it. what motor do you have? i just putt 31s on my 4runner and i have the 2.7L 22-RE and those 31's bogged it down at high speeds a bit. it does fine getting up to 60 but from there to 70 and up its sluggish. thats the only thing i would worry about, you can fit them but you might have trouble turning them. if you do go with them a few things you can do to get your motor to turn them better is do a cold air intake, long tube header, and a new muffler. that only costs about $250 and you will notice a definite increase in power.
Old Sep 24, 2007 | 05:37 PM
stormin94's Avatar
yes, 32's will fit, you might have to trim a little.
Old Sep 24, 2007 | 05:54 PM
BluYot's Avatar
Yes...I think you could even go up to a 33". Just don't go wider. You did search?....I remember looking it up back in the winter and there are tons of threads. Give it a try again...but in the meantime go get your 32's!
Old Sep 24, 2007 | 06:24 PM
4Crawler's Avatar
On a solid front axle truck, 31x10.50 is about all you can fit w/o a lift w/ stock wheels. Tires will rub at the rear of the front wheel well, because unlike on an IFS truck, the front axle moves backward as the springs compress due to the front spring shackles swinging backwards. Some trimming/flattening of the standing seam can help, but you may need to add a longer front spring shackle (1"-2") or a body lift (1"-2") to gain some clearance if needed. In back, they will fit OK, although they may rub on the frame if you have good axle articulation. Fixes include less backspaced wheels or wheel spacers.
Here is my '85 4Runner w/ 33x9.50 tires and 3.5" of lift, tires rub even straight ahead:
Old Sep 25, 2007 | 10:20 AM
85toy's Avatar
well i think im gonna go for it enen though 4crawlers picture scares me i was thinking of doing a shackle lift anyway, and i dont really have a problem with triming a little. thanks for all the feedback, i will post pics of it with the new tires. thanks everybody.
Old Sep 25, 2007 | 02:37 PM
85toy's Avatar
well i called the guyagain today to make sure he still had them but they sold at 7 am. oh well i guess ill keep looking.
Old Sep 25, 2007 | 02:52 PM
hanksyota's Avatar
pm Axleike. he has 33's on a SFA 4runner. i dont think he has any lift, just some stuff to fix the saggy butt.
BushPig
Oct 29, 2022 06:26 AM
XtraCab
Apr 12, 2020 05:25 AM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
