Broken Valve Springs
Old May 18, 2008 | 06:38 AM
coltonk's Avatar
I bought a new(?) head off ebay.. The head seems fine but I keep breaking valve springs. I broken one about 10 miles ago, then rebuild the motor and took it on its first real run and broke 2 more, each one was on a different cylinder, 1 intake and 2 exhaust.
The vavle spring breaks near the head and has enough weight or something to keep the retaining clips from coming out (I'M lucky i know). The springs I broke yesterday, I had to drive it 30 miles to get home, wasnt sure what was going on except it was running bad!!
Has anyone else experienced this??
Old May 18, 2008 | 06:44 AM
Hayes's Avatar
Sounds like cheap springs or something isn't setup right...
Old May 18, 2008 | 12:26 PM
deserttoy84's Avatar
you either need to go buy OEM springs OR
Learn how to properly adjust valves.
Old May 18, 2008 | 01:41 PM
SEAIRESCUE's Avatar
Are you using a stock or OEM camshaft? Appears to be valve spring bind. I believe you need to contact whomever you purchased the head from and read them the riot act. If not spring bind, they are brittle and failing (read not to spec). However, if you have shoved some after-market camshaft in the head, you own the problem. While rotating engine by hand, inspect the springs for bind.
My $0.02
Old May 18, 2008 | 02:44 PM
coltonk's Avatar
It must be my fault then... When I rebuilt the engine I did put in an RV cam..
What is spring bind and how do you fix the problem.
Old May 19, 2008 | 04:00 PM
what cam are you running(brand name)??
Old May 19, 2008 | 05:51 PM
coltonk's Avatar
not really sure since the machine shop got it for me. I do know it is modified in seattle washington from a stock cam
Old May 20, 2008 | 09:02 AM
Might want to call the machine shop and tell them whats going on. Or talk to ted at engine builder (www.engnbldr.com).
the1998sr5
15
Jul 14, 2020 08:35 PM
nvdesertrunner
May 11, 2020 08:18 PM
gmonnie123
Jul 26, 2015 02:44 PM
voiddweller
Jul 15, 2015 03:56 PM
cars-guy
Jul 11, 2015 07:51 PM
