black sut in clutch master cylinder
Old Dec 18, 2009 | 04:53 PM
brianrbhutch's Avatar
went to make a run and was checking fluids and noticed clutch was a little low, proceeded to add a little fluid and there was a blackish dark gray substance kind of swirled around in resivoir, i over filled to make it run out adjusted level and went on my way later on pushed clutch felt funny pressed again to the floor it went jumped out to see if fluid was gone, it was still full but almost black double clutched it home, figured needs new master and slave but would like ideas. what would cause the black sut
Old Dec 19, 2009 | 05:59 PM
myyota's Avatar
It wouldn`t be a bad idea to replace both and flush the lines.
Old Dec 19, 2009 | 06:02 PM
4Crawler's Avatar
Could be the fluid just got old, it'll turn very dark with time and not flushing it. Or it could be a seal or flex line had started to disintegrate and it was than black rubber residue you saw.
Old Jan 5, 2010 | 03:18 PM
stormin94's Avatar
What kind of fluid does it take? Is it just simply "clutch fluid"?
Old Jan 5, 2010 | 03:21 PM
ToyoTech559's Avatar
brake fluid goes in clutch reservoir
DOT 3 should be fine
Old Jan 5, 2010 | 03:22 PM
stormin94's Avatar
Ok, cool. Thanks.
Old Jan 5, 2010 | 03:24 PM
Kiroshu's Avatar
A flush is not neccesary and brake fluid does not get "old" It either gets contaminated or dirty. Make sure your reservior is on all the way and make sure its not leaking anywhere. If it was low its prop leaking look at the rubber line down near the trans. Its it saturated? Thats prob the issue. Brake fluid always.
Old Jan 5, 2010 | 03:29 PM
in a sense it does get old, well kinda. even if it doesnt get dirty or contaminated by wear and tear. brake fluid absorbs moisture which is in the air around us. moisture will break down the fluid and its best to change it out every 2 years
Old Jan 5, 2010 | 03:39 PM
stormin94's Avatar
I might have a leak somewhere, since there's some fluid near the top of the trans that's leaking from somewhere. And my clutch pedal was kind of stiff today. I'll have to check that out tomorrow, since it's getting dark out right now.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
ty1er
Aug 1, 2015 11:53 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
