Belt issue
Old Feb 21, 2010 | 02:50 PM
Travisfab's Avatar
Belt issue
I am having trouble getting my power steering belt to line up. From the upper pulley that is adjustable, down to the crankshaft pulley, the belt it as at a noticeable angle. I recently replaced my power steering pump, and this issue came up. The new pump is the correct one, I even tried the pulley off the old pump. I've also tried every thing I could possibly think of to adjust the top pulley. I tried a 2nd belt and it was a little better, but it was not a new belt. I pitched the belt off 3 or 4 times this weekend out in the desert.
Thanks
Old Feb 24, 2010 | 09:59 PM
toyotabull's Avatar
Might be the crank pulley. is the top pulley too forward of the crank or set back towards the motor behind it?
Old Feb 25, 2010 | 10:53 AM
Travisfab's Avatar
The top pulley is too far forward. Weird thing is, is that everything worked perfectly before I messed with it. (minus a leaking PS pump)
Old Feb 27, 2010 | 06:55 AM
85 SR5 Man's Avatar
Mine worked fine to till i changed my p.s. pump now it won't start
Old Feb 27, 2010 | 09:31 AM
Travisfab's Avatar
PS pump should have nothing to do with it starting. I have determined that I need a 3 groove crank pulley. Some how it worked on a 2 groove up until now.
Old Feb 27, 2010 | 09:35 AM
BigBluePile's Avatar
IIRC the outer groove on the 3 groove pulley is for A/C...isnt' there a spacer/washer thingy on the ps pump pulley? Someone else had this problem and I think that was the issue...
Old Feb 28, 2010 | 05:40 PM
Travisfab's Avatar
From what I have gathered the 3rd groove pulley bolts on, and is for the power steering.
Old Feb 28, 2010 | 06:04 PM
nope you're right, had to go look at mine, that bolt on one runs the fan/ps pump with the center turning the a/c. Is there a spacer installed on the new pump?
Old Mar 4, 2010 | 05:55 PM
Travisfab's Avatar
There is not really any way you can put a spacer on the PS pump. It bolts on with 4 bolts and the pulley shaft has a tooth that the pulley has to slide in on. 3rd (bolt on) pulley is going on saturday, problem solved, time to race!
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
cgilley
Jul 25, 2015 10:55 PM
toofly1999
Jul 25, 2015 07:09 PM
nick b
Jul 11, 2015 04:38 AM
