another blown diff...
Old Oct 3, 2011 | 07:29 AM
runs-on-4's Avatar
ive now blown 2 rear diffs in about 2 weeks. this is right after my tranny and tcase swap. first diff a tooth off the ring chipped and somehow made the pinion grind on the carriring case. the second i had laying around and was welded. i went wheeling yesterday and i think a weld broke, but it broke through my axle.. now im on the search for a new set of 3rds. what cold be causing this? or is it just a coincidence?
Old Oct 3, 2011 | 07:34 AM
xxxtreme22r's Avatar
When a weld breaks on a Lincoln locked diff, all kinds of bad things happen.
My vote, coincidence. Or the housing wasn't completely cleaned out when you swapped the broken toothed 3rd for the "new" one.
Old Oct 3, 2011 | 08:06 AM
runs-on-4's Avatar
i cleaned it out pretty well, im think coincidence as well.. i should be able to weld up the hole in axle and get some 5:29's!!
Old Oct 3, 2011 | 08:08 AM
waskillywabbit's Avatar
I think it's the operator
:wabbit2:
Old Oct 3, 2011 | 08:14 AM
runs-on-4's Avatar
haha probably, i tend to beat on my runner... but i think i have the only front wheel drive 4runner right now
Old Oct 19, 2011 | 07:25 AM
mommucked's Avatar
Is your pinion angle raised up from stock from a lift?, If so try parking it on a hill to point the snout down and add more oil to the housing. If you just fill to the filler hole w a raised pinion on level ground the pinion bearings can get less lube and fail alot sooner than normal.
4banginRunner
Nov 13, 2015 05:23 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
alexcarey
Oct 14, 2015 06:05 PM
Toys4parts
Sep 26, 2015 01:56 PM
