alum. radiator?
Man I love this radiator its a likttle shorter than the one that was in there (which is good) a even pulling up a long rough hill the temp gauge didn't move !! mark that off my upgrade list
#25
#30
OK, my aluminum radiator has arrived. I'm gonna put a Taurus fan on it and I've vented my hood.
Now, looking at the radiator, down thru the filler neck, it appears to be a single core radiator? Is that right? I though it was a dual core?
Probably my bad and I'll be putting it regardless. I also see some questionable welds on this unit, I'll take a pic before I put it in.
Considerable lighter than my old radiator, so that's a good thing!
Oh, and how does the tranny cooler work? is it just a little coil in the bottom tank? It must be, I can't see any other way for it to work. That makes me want to not use that cooler and maybe I should install a larger dedicated tranny cooler. I do run the tranny darn hard sometimes (I should start a thread on possible effects of running the tranny fluid level way high to prevent drainage on steep hills).
Ahhh, life is full of questions.
#31
Well, here's the way it's turning out. I wanted to make sure I wouldn't overheat again, so a few months ago, I started the process.
I put louvers in the hood.
I put in this Alum rad.
I need to finish the B&M tranny cooler
I need to finish (don't have it yet) the install of the Taurus fan.
Oh, and I removed the A\C condenser for better air flow to the radiator (my winch still in the way tho, on top of the bumper, bad location).
kawazx636
Oct 6, 2021 03:03 PM
scott90
Oct 4, 2015 09:21 AM
