87 4runner starts and smoothly runs for 10 seconds then dies.
Old Aug 5, 2017 | 02:46 AM
owlhowler's Avatar
The actuator in the afm throat is starting the fuel pump as it should. the vehicle sat for a long time. two sets of mobile mechanics have been unable to fix it. Fuel pump has been changed.My next step is to run an independent power source to the fuel pump to make sure the ecu is not switching it off. I welcome suggestions
Old Aug 5, 2017 | 03:53 PM
wyoming9's Avatar
Red face
Your a little off there The switch in the AFM keeps the fuel pump running after the engine is running
There are two coils in the Circuit opening relay one just might be open
None of those Mechanics knew enough to troubleshoot fuel problems by jumping B+ to FP on the check connector
That bypasses all the switches and the Circuit opening Relay unless you have physical damage to the wires no reason to hot wire the fuel pump
Old Jan 10, 2022 | 09:05 PM
Kracker's Avatar
we had this issue after ours sat. it would run about 5-10 seconds great then die. it was because the injectors rusted closed. id bet money its your issue. if it will keep running on carb cleaner, there you go
bsoccer
May 25, 2020 09:24 AM
jharriet
Feb 26, 2014 01:22 PM
jaredhicks
Mar 7, 2013 09:14 AM
jyama99
Dec 28, 2009 01:48 AM
myyota
Jun 7, 2007 01:24 PM
