85 transmission problem
Old Jul 19, 2007 | 03:41 PM
liftedokie85's Avatar
I put in a new motor and clutch in my 85 pickup and when i put in the clutch fork i was not sure if i put it in correctly. Nom the fork is very loose but when i push it in it gets a little stiffer but the transmission will not go into any of the gears. (It just grinds.) Any thoughts on fixing it. How if the fork suppose to feel?
Old Jul 19, 2007 | 04:24 PM
nat88toy's Avatar
i had the same problem turned out that the transmision that i had in my 88 4runner was out of an 89 so the throwout bearing was the wrong size. I took the original to the parts store and looked at a bunch of throwout bearings of different years untill i was able to match up the right size
threre is also an adjustmet on the clutch peddel but i dont think that it will help you in this case
good luck, nat
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
