22RE Staring Problem
Old Jul 17, 2007 | 06:32 PM
corvettelvr73's Avatar
I have a problem with my starter sounds like contacts so I changed the contacts same problem so I changed the whole starter same problem I checked the relay and it looks good to me. When I turn the key it makes a clicking sound like the battery is dead but I know its not. I have to keep turning the key over and over sometimes for 5-10 mins and finally it will turn over blowing smoke out the tail pipe. Does anybody know what the problem could be. Thanks
Old Jul 17, 2007 | 06:54 PM
locked stock 84's Avatar
have you checked the teeth on the flywheel? pull the starter and turn the motor over by hand while inspecting the gear ring.
Old Jul 17, 2007 | 08:08 PM
I will check it but I dont thing its that but thanks anyway andone else know what it could be
Old Jul 17, 2007 | 09:13 PM
4Crawler's Avatar
Perform a simple voltage test at the starter when you get the click:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
If you see more than a 1/2 volt drop to the starter solenoid you may have an electrical issue upstream from the starter, some options to fix those on the web page below:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Jul 17, 2007 | 09:14 PM
89silverpu's Avatar
22re's have eyes?? hahaha
Old Jul 18, 2007 | 05:59 AM
rdlsz24's Avatar
Mine did the same thing. I replaced the starter and all is well.
Rob
Old Jul 19, 2007 | 10:12 AM
But mine still does it. Could it be the starter relay
Old Jul 19, 2007 | 10:18 AM
4Crawler's Avatar
Do the simple voltage check I posted a link to earlier and you will know. And not all 22REs have starter relays, I know my '85 does not (at least as it came from the factory, I later installed one).
Old Jul 19, 2007 | 10:34 AM
DeathCougar's Avatar
I wonder if they do Lasik on 22re's to correct that staring problem....
That should fix it!
Old Jul 19, 2007 | 11:06 AM
denro's Avatar
when my starter clicked, i took the end off the solenoid on the starter and flipped the washer in there over. worked for me
Old Jul 19, 2007 | 09:05 PM
But I have a NEW starter so it couldnt have anything to do with the starter
Old Jul 20, 2007 | 06:54 AM
4Crawler's Avatar
New or rebuilt? If rebuilt, don't necessarily assume it is not the problem. Have heard of quite a few occasions where "rebuilt" starters were not totally rebuilt. I think that many times, the core is brought in and tested and if it seems OK at that time, they get cleaned and repainted and put in a box. Not uncommon for a rebuilt starter to have worn contacts in the solenoid.
Doing that simple voltage test (under load) posted earlier will tell you where to look for the cause of the problem:
jbv808
Aug 6, 2021 04:47 PM
steve miller
Oct 10, 2015 01:40 AM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
ryerye13
Jul 14, 2015 08:27 AM
