85 Toy looking for options for a 5" lift
Old Feb 21, 2009 | 12:08 PM
Stifun's Avatar
Thumbs up 85 Toy looking for options for a 5" lift
Redoing my suspension looking for a good quality lift kit right now the only one I have found is the Skyjacker 5" and I want replacement rear springs not blocks. Could you help me find out what my options are. Also with the lift kit I plan to run 35 BFG All Terrains.
Please help.
Old Feb 21, 2009 | 12:14 PM
Wardamneagle's Avatar
For 5" I would go with the Marlin Crawler kit.
Old Feb 21, 2009 | 12:40 PM
Ed H.'s Avatar
maybe plan on getting some gears with the lift if you plan to go 35's.
Old Feb 21, 2009 | 12:54 PM
Stifun's Avatar
I have gears already 4.88 because I have 33's on now but I got such a good deal on the 35's that I will run those with my new lift. Also would I need a crossover steering kit with this lift.
Old Feb 21, 2009 | 02:18 PM
Trustyrusty's Avatar
If you want sickk flex and quality get Marin, Trail Gear, or Allpro.. TG is cheaper, and makes just as good stuff I think.
If you want life, mediocre flex, and a cheap price, just get a generic Pro-Comp lift kit with the ES3000 shocks for like 3-4 hundered bones and call 'er good..
Old Feb 21, 2009 | 03:53 PM
waskillywabbit's Avatar
4" lift springs will be plenty to fit 35s, perhaps 1" taller in the rear if you have a 4Runner as opposed to a PickUp.
Old Feb 23, 2009 | 07:47 AM
Stifun's Avatar
I have a pick up and plan on doing a 5" and a 2"body lift to replace worn out bed mounts. Also WABFAB I just really want a new lift without spending a lot of $$$ will your 5" springs work as in reality I just need to change my springs as they are worn out and later buy new shocks. What do you think are your springs just bolt-on's and are they replacement springs or will I need to do any modifications to axles or anything else.
Currently I am running a 4" suspension lift front and 3" suspension lift rear with 3" blocks. But my current set up is old and needs new leafs.
Old Feb 23, 2009 | 01:41 PM
Stifun's Avatar
bump for an answer. Also a fellow member is selling Skyjacker 7" spring used would this be too tall with a body lift for 35" tires.
Old Feb 23, 2009 | 02:49 PM
1989toy4wd's Avatar
Thats going to be a lot of lift, I am running 37s with marlin 5in springs and 4in shackles, so I got 7in of suspension lift. I think its too tall though, and I rub on the body (i refuse to do a body lift though).
I heard the pro comp springs ride really rough too!!
Old Feb 23, 2009 | 03:47 PM
Dirt Master80's Avatar
5" lift
I run 5" skyjacker springs with a 2" body lift on 36's.ive cut my fenders out and still rub but the skyjacker springs dont move you axel forward like the the highend lift kits. you get alot more room if the axel is moved forward an 1 1/2". the springs have been good and it flexes decent. thier a direct bolt in no mods required
Old Feb 23, 2009 | 09:03 PM
Stifun's Avatar
Nice just what I wanted to hear so how is the body lift is it Ok have you been happy with it and is it a pain to install. I also would never think of doing a body lift but my truck is creaking from the old body mounts as they are cracked so that is why I am doing it. Also do you think with the Skyjacker lift and my body lift will I rub when flexing I plan to run 35 BFG All Terrains on a 15X8 wheel.
Old Feb 24, 2009 | 10:21 AM
Stifun's Avatar
So what kind of shock is good for my amount of lift I have always used Racho Shocks is there better ones now or are the Skyjacker one's pretty decent as my truck is mostly street use and a little towing with my 18ft boat.
Old Feb 24, 2009 | 11:06 AM
854Runr's Avatar
If i were u id save up your money and go with a lift from allpro, trail-gear, etc. Its definitly worth the extra money. Plus im a newbie home mechanic and i was able to install my lift in my driveway on jack stands.
If your trying to save money where you can think about the chevy swap in the rear. They work awesome.
Im also runnin procomp es9000's and they seem to be pretty good for the price.
Old Feb 24, 2009 | 11:39 AM
mikepr55's Avatar
Marlin is expensive but go to thier web site and check out the flex and performance. It's awsome but probobly pretty advanced on the instal I don't know if you want to get that involved. Also checkout www.addictedoffroad.com[/url] SICK!!!!!!!!!!!!!!
Old Feb 24, 2009 | 03:31 PM
Stifun's Avatar
Well I am older now and just don't do much wheeling anymore so I am just looking for a cheap lift kit so my truck rides better and I can fit my new 35" tires. So for now I think I will get the Skyjacker lift as it meets my needs unless I can find a used Marlin, AllPro lift kit for less $$$
Old Feb 25, 2009 | 04:48 PM
Stifun's Avatar
So any suggestions for Shocks for my set up and what length should I get for some decent flex if I every go off road.
Gio8
Aug 27, 2015 12:14 PM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
msane99
Jul 17, 2015 10:13 AM
Vargntucson
Jul 4, 2015 12:15 PM
