85 Pickup No heat issue
Old Jan 3, 2011 | 02:41 PM
Kjoslyn's Avatar
Heres me and my truck (84 toyota 22re swap header stage 3 cam, chip hybrid rears and tj springs up front chevy springs in the rear ect....) were working on getting a bumper....
The heater isn't working so I am freezing my a$$ off snow wheeling... any ideas? the hoses to the heater core are warm and heater kinda works after awhile but still not warm enough... my temp stays normal and heats decently fast...??
Old Jan 3, 2011 | 06:45 PM
mightymouse's Avatar
nice rig kjoslyn try replacing the t-stat and flushing the system. If that fails then it's on to the heater core and tearing into the dash.
Old Jan 3, 2011 | 07:33 PM
drew303's Avatar
Flush the core out. Disconnect the inlet and outlet hoses in the engine bay. Get a pt style spray nozzle for the garden hose and wedge it in and flush. Worked for me on every clogged core I've dealt with.
Old Jan 3, 2011 | 07:57 PM
check the wire that the switch activates at the inlet to the heater core. Mine has come disconnected before and took me a little while to find it. On the fire wall towards the middle of the driver's side. Should be a coupler between two hoses with a wire connected to the bottom of it. make sue the wire is connected. Right next to the master cylinder.
Old Jan 3, 2011 | 08:15 PM
here.
Old Jan 4, 2011 | 06:44 AM
xxxtreme22r's Avatar
Kjoslyn you might have the same problem I did where the wire does not move in an out. All I did was open that valve by hand till the valve started leaking then I just took the valve out and "permanently" bypassed it.
As far as Rausch Creek goes:
our last trip there:
https://www.yotatech.com/forums/f100...t=Rausch+Creek
and the trip before that:
https://www.yotatech.com/forums/f100.../#post51404603
There are quite a few other trips there if you use the forum search as well.
Also here is a link to the main Park page: http://www.rc4x4.org/
Old Jan 4, 2011 | 11:08 AM
Kjoslyn's Avatar
more heater issues
ok so mine looks different than yours... heres what it looks like
is this what your taking about? doesn't seem like a leaver just holds the hose?
Old Jan 4, 2011 | 11:21 AM
there should be a lever there that is actuated by the cable from the heater control that opens and closes the valve. Pic is kinda blurry but should be in the area that you pointed out.
Old Jan 4, 2011 | 12:01 PM
thanks dc.
Old Jan 4, 2011 | 12:15 PM
Lumpy's Avatar
Thanks for the move!
It almost appears that the linkage is there but the valve has been removed...
Check out these 2 threads when you have some time.
https://www.yotatech.com/forums/f47/...eelers-198859/
https://www.yotatech.com/forums/f15/...anning-203062/
Welcome to the group!
Old Jan 4, 2011 | 12:42 PM
92 TOY's Avatar
ok...I'm in.
my heat works so I have no help for you except a WARM welcome......ain't that cute.
Old Jan 4, 2011 | 12:43 PM
92 TOY's Avatar
by the way the links LUMPY posted are all us...and a few others
Old Jan 4, 2011 | 12:46 PM
Lumpy's Avatar
Hey there 92_Toy...Nice of you to help help out...
Do you have any good images of the firewall in and about that area. I checked to see what I have and I didn't have anything useful in that area. Almost looks as if something there is missing. Maybe just me though.
Old Jan 4, 2011 | 01:08 PM
92 TOY's Avatar
I will check after I'm done doing supper.
Old Jan 4, 2011 | 01:27 PM
valve is there, that's what my 87 looked like.
Old Jan 4, 2011 | 01:35 PM
92 TOY's Avatar
ummmmm...this is no help (3vze...motor out)
top view 92 22re
bottom view
i do believe the valve is different in the earlier years if my memory is correct
Old Jan 4, 2011 | 01:38 PM
yup, that's the newer style valve. I would take photos of mine, but like I said earlier I "bypassed" mine.
Old Jan 4, 2011 | 01:47 PM
yotarob2005's Avatar
I can get some pics of mine when I get home this evening, its an 86 so I'm pretty sure it has the old style.
Old Jan 4, 2011 | 01:50 PM
92 TOY's Avatar
I was thinking of you or Chef or TOYOSPEARO
Old Jan 4, 2011 | 02:04 PM
92 TOY's Avatar
I will edit this post as I find pics.....going through TOYOSPEARO's 1982 truck build thread
EDIT......that's all I've found
