85 4runner lift?
85 4runner lift?
i am looking to buy a lift.
it will be a daily drive. cream puff a few days a year.
1985 4runner soild axle front
31" mud tires
all else stock
i am looking at the Pro Comp kit 4" with all shock,4 leafs, drag link, bump stops, extended brake lines. pretty much ever thing
new in bow from 4wheelParts with sale and coupon codes..
what is the genral thoughts on the pro comp lifts?
thanks for your help?
p.s. i also plow my drivway with this 4runner
31" mud tires
all else stock
You are probably going to want hysteer with 4" of lift... Just my two pennies.
After you get the lift installed, I think you will quickly change your mind. Just wait till you have to slam on the brakes... Hold on and enjoy the roller coaster!
Most aftermarket high steer arms use FJ80 TRE's. I drilled the taper out of my tie rod holes and used 3/4" heim joints.
Make sure you brace your frame before you mount the IFS box.
Is the hi steer for mostly off road ? the kit comes with a 4” drop drag link? I understand both concepts? But what is the difference on the road?
One response is when I hit the brakes ? I don’t understand this ?
just a dumb newbee question
i've never had high steer...but i've had a solid axle toy that was lifted (by the looks of it..)
and when i hit the brakes..it would dart around..not like a brake was grabbing more than another...it was the steering.
if i let go of the steering wheel, it would spin ALLL the way to left by itself..lol
the High Steer kits are just a BETTER steering setup...it's just A LOT better all around..stronger, easier, quicker (because of the IFS box)..it's just ALOT better.
I agree with camo31"10.50, i had the stock steering on my 84. Its just the J pattern steering arm on the drivers side knuckle, it has to make so many twists and turns to get the tires moving left or right. Just an engineering nightmare. The IFS box with left/right instead of the push pull design works 1,000% better IMO. I drive mine on the road alot and the hysteer just works great. Your 4" procomp lift is probably for "off road use only" they just like to put those disclaimers in there so they wont get sued.
