85 4runner having some serious issues
Old Dec 21, 2010 | 11:48 AM
yoter85's Avatar
My 85 4runner is really screwing up. It runs good when its cold. But as soon as it starts to warm up the check engine light will flicker on and off. There is no rythm to it just random flashes. But thats not the actual issue. The real issue is when it does that flicker i go to push the throttle and its none responsive for a moment then it sounds as if its flooded. Then a few moments later it will stop sputtering and red line but usually continues to sputter even after that. I get a cloud of BLACK smoke and you can smell the unburnt fuel. I have replaced mass air flow sensor, coolant temp sensor. What else could it be? Throttle position sensor? Ecu going bad? I am at a loss.
Old Dec 21, 2010 | 11:55 AM
4Crawler's Avatar
You did not indicate if there were any code(s) stored in the ECU, but they may tell you what is going on:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Dec 21, 2010 | 03:22 PM
OrRunner's Avatar
has some simalar issues not to long ago, however i could throttle out of the sputtering, but i was running extremely rich, mine turned out to be my ecu had gone on me...
Old Dec 25, 2010 | 03:11 PM
myyota's Avatar
The three things i would check are the TPS, 02 sensor, and the idle air control valve.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
HRDC0R19
Jul 5, 2015 06:43 PM
