'85 4Runner Build...
Old May 7, 2006 | 07:44 PM
  #81
Newb's Avatar
Inserted the Poly bushings, grease the bolts & the inner side of the bushings as well as you can. If you have or are thinking about placing a order with trail-gear I recommend getting the greasable bolts for the shackles.
Before hacking off the bumbstops & rear spring mounts. If you notice the Brake hose is fully extended & pulled tight. I took the rubber hose off the parts truck and connected it with the steel braided one as a quick cheap fix for the time being.
After...
Setting the Springs...
First attempt, poor shackle angle...
Much better...
Flexed a little...
Old May 7, 2006 | 07:52 PM
  #82
Newb's Avatar
Stripped all the plastic out except for the two panels beside the backseats(Safety Reasons) & then sprayed everything down with bedliner including the rollcage.
Old May 8, 2006 | 01:57 AM
  #83
1985 4Runner's Avatar
looking great man! I like the cage padding too. Good to see you're making progress
Old May 8, 2006 | 03:29 AM
  #84
Newb's Avatar
Yeah its slowly happening, I'm not sure what I want to do next though. Time is running out so my options are limited. I think I'm gonna lose the one leaf out the buggy leaf pack, its not as flexy as I'd like it to be.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
