85 22re pickup runs rough cold and wont hot start
Old May 14, 2018 | 08:55 PM
Dorsalf1n's Avatar
amd won't hot start86 toyota pickup was stolen and recovered the next day. they took everything, electric fan and switch, headlights, cemter console wheels, im mean everything. even my prop rod for the hood. but it ran. i had it towed because it had one small wheel on it. got it home and it sat for 3 months while i ordered new stuff. finally got everything and wenr to start it and wouldnt even idle without putting full throttle on it. evem then it would cut out and sputter and barley stay running. untill it gets hot then runs tottally normal. but when i shut it off it wont restart. engine turns over but wont start. anyone got advice? ,,
and while the truck was running it pulled codes #2 air flow meter sensor #3 no ignition signal from igniter #6no ignition signal #8intake air temp sensor or circuit #11ecu main relay. i dont think all those would go out at the same time.
it has new spark plugs wires and cap and rotor. ive made sure evwrything was plugged in, also no bare wires exposed
Old May 15, 2018 | 04:27 PM
mikestevens's Avatar
sounds like you have a host of problems.....My advice would be to take it to a dealer first, they will give you a list of things to fix and when your done, go back for more advice. Im sure you want this to work like new!, It might be a long road for you until you get all the puzzle pieces. Good luck.
crasster
Jan 14, 2019 09:06 AM
edmondsonknives
Jan 8, 2017 07:34 PM
GoldenBeaR6
Dec 11, 2013 06:26 PM
WYrider
Jan 10, 2012 12:21 AM
code1p36
Oct 31, 2011 07:46 AM
