85 22re aux air valve
Old Apr 14, 2015 | 07:01 PM
samx227's Avatar
have a question about testing the valve. my buddy said to pull the air hose behind it and if the idle goes up its most likely a clogged port. i pulled the hose off and the truck wouldnt idle and if i tried to hold the throttle up it missed. put it back on and ran fine. pulled the hose in front and it idles super low. any way at this point what would be my next step? the problem im having is no fast idle on cold starts.
Old Apr 15, 2015 | 03:52 PM
58rennur4's Avatar
FSM usually helps but what the hell... here....
Old Apr 15, 2015 | 06:32 PM
osv's Avatar
osv
if it's doa, don't bother repairing it, just do the later model intake swap: http://www.pirate4x4.com/forum/toyot...take-swap.html
Old Apr 15, 2015 | 07:26 PM
samx227's Avatar
Osv that is tempting seeing as I can only find the part at the dealership. $202 and that's at my employee price. Thanks guys.
Old Apr 16, 2015 | 03:15 AM
58rennur4's Avatar
I wasnt aware you could stull get these new. At least not for 1st gen.
Old Apr 16, 2015 | 05:43 AM
samx227's Avatar
Yeah I got the p/n off my truck and it's still available according to my parts guy. Haha
Old Apr 16, 2015 | 10:18 AM
osv's Avatar
osv
$202 ouch! lol
you can get the entire swap used for that much, or less, and it's much better.
helpful tip: i was able to use the '86 throttle cable, by cutting the very tip off slightly with a die grinder, and screwing on one of the dorman help barrel ends... i think that i had to drill the barrel out very slightly tho.
Old Apr 16, 2015 | 12:19 PM
58rennur4's Avatar
Yea I think they show available but are not. 22230-35010 is mine for 85 4runner and they are gone with the wind.
Old Apr 16, 2015 | 12:31 PM
samx227's Avatar
Same p/n as mine. Showed available but who knows until he orders it I guess haha. I'll be looking in to the newer manifold swap.
Old Apr 17, 2015 | 04:50 PM
58rennur4's Avatar
Just saw one listed on Ebay looks pretty clean but was used. Not sure what the new manifold swap cost or if it is worth it...
Old May 26, 2015 | 05:14 PM
sea dawg's Avatar
Got a question regarding my '85 truck with a 22re. It has recently started a really fast idle at cold start up. This lasts for about 20-30 minutes, and once I get up in the mountains it settles down to its normal 800RPM or thereabouts.
My truck appears to have a motor from a 1990 truck in it; judging from the code on the intake and the fuel injectors that were on it. I've had numerous issues getting it to run on the 1985 computer, and along the way have done the following:
- all new vacuum hoses; threw away the metal spaghetti from the 1990 and routed everything straight with new vacuum hoses
- replaced the master cylinder and booster, due to loss of idle under heavy braking
- replaced fuel injectors with '85 model
- replaced the rubber boot coming from the air cleaner to the intake
This truck does not seem to have an aux air unit for warm-up. My '87 had one, and I ended up rebuilding that one, but I don't see one on this engine. Was the '85 model EFI supposed to have one???
Old May 26, 2015 | 06:29 PM
osv's Avatar
osv
did you read the intake swap link that i posted? because it'll tell you what you have now.
Old May 26, 2015 | 07:25 PM
sea dawg's Avatar
The intake swap discussion that I saw was talking about trucks in the 86-90 range. For whatever reason, my 85 does not seem to have one on it that I can find. Perhaps I just need to look closer? On my last Toy, it was underneath the front of the air intake (the front of the air dam or whatever the correct term is for it.) I've had this thing taken down a fair piece, but have yet to see a cold idle air mix box on it?? That's sort of the confusing part.
Did the 85 use this type box, or did it use some other method for the fast idle at startup?
Old May 26, 2015 | 08:27 PM
osv's Avatar
osv
you said that your truck had a 1990 engine in it, so it should have the later model plenum swap already.
look at the post from pappy in that thread, he has pics of both plenum types.
Old May 26, 2015 | 08:41 PM
samx227's Avatar
I believe the 90 model did not have an auxiliary air valve. It should be "built in" to the throttle body
Old May 26, 2015 | 09:42 PM
sea dawg's Avatar
Thanks, I missed that!! Will look again!
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
sojourner567
Jul 16, 2015 08:52 PM
ryerye13
Jul 14, 2015 08:27 AM
