84 toyota pickup
Old Jan 20, 2015 | 07:53 AM
heavyd1980's Avatar
84 toyota pickup
Hey guys anyone have any idea why every time I go to start my 84 22r truck that you have to "bump" the key several times before it will engage the starter? The starter was replaced over a year ago, the battery cables don't have any corrosion and they are tight. Thank you for all the help in advance!Delano
Old Jan 20, 2015 | 08:16 AM
JasonYota's Avatar
Could be the actual ignition switch
Old Jan 20, 2015 | 05:22 PM
slacker's Avatar
how about the ground cables where they attach to the body and motor ?
Old Jan 21, 2015 | 04:20 AM
heavyd1980's Avatar
How many should there be attaching to the body? There should only be one that attaches to the engine correct?
Old Jan 21, 2015 | 04:54 AM
AZkid's Avatar
https://www.yotatech.com/forums/f116...-guide-194413/
I would ensure that these grounds are clean and tight, next i would look into the starter relay.
Old Jan 21, 2015 | 06:32 AM
heavyd1980's Avatar
Awesome! Thank you I will get to looking at those quickly!
Old Jan 27, 2015 | 08:15 AM
bootscootboogie's Avatar
Im throwing this out for clarity's sake: are you pumping the gas about 3 times before you turn the key...
Old Jan 27, 2015 | 08:44 AM
JasonYota's Avatar
He's saying it won't turn over till after a few tries. Pumping the gas won't do anything
Old Jan 27, 2015 | 06:41 PM
Gotcha. I only said that because if I don't pump my gas.... Etc etc
Old Jan 27, 2015 | 07:33 PM
Terrys87's Avatar
Cleaning the Starter Relays contacts helps as well. I will see later if I can find the link showing the contacts. I got it somewhere, just got to find it. I used some fine grit sandpaper to clean the contacts. RAD4Runner has some great info on his build thread as well.
I used a screw driver to work around the edges of the seal to help free the cover.
Old Feb 12, 2015 | 08:13 AM
Steelforce's Avatar
Nice
Good picture.
Old Feb 13, 2015 | 08:02 PM
Cookie Monster's Avatar
Occasionally i have to get out and smash the starter with something... I can hear the relay click but no crank on the starter.
You say its a year old, but they do sit near the wheel well, could be a dirty/sticky starter?
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
