84 temp gauge reads half all the time
Here's the issue. Immediately after start up, temp gauge shoots to halfway and doesn't move. Doesn't appear to be a common issue since I can't seem to find any info on it. Anyway, the question I have is should I be looking into replacing the water temperature sender gauge or the water temp detect switch? Not too sure which one and the service manual isn't very specific on which one does what. Any info is greatly appreciated. Thanks
I did the test and the guage went straight up, I'll buy a temp sender since its like 8 bucks. My problem is that on the highway it shoots straight to hot but as soon as I exit and pull over it goes back down. I don't think the engine could cool down that quickly. Also I shot it with a temp guage and it was at 190. If I chose an aftermarket guage would I inset that into the spot where the original sender is. Will there be a fitting available that is the same size?
got my temperature sending unit from autozone and it dropped right in. Your experiencing the typical temp overshoot. Stock thermostat is one ninety i got one that's 160 or 180 can't remember lol.but i like mine to run cooler. I can sit at idle with the air conditioner on covered in mud and she barely gets halfway hot
Ok got one and put it in. I noticed the old one had Teflon, I heard that was a no no. The new one was slightly longer. When I tried to tighten it it would keep turning. It got snug but didn't come to a stop. Didn't want to strip the hole or mess the o ring up on the sensor, I drove around for a bit and didn't see any coolant leaking out. Temperature still went up though like previously
the1998sr5
Oct 19, 2016 12:48 PM
Vargntucson
Jul 4, 2015 12:15 PM
B. Graves
Jul 3, 2015 04:10 AM
