84 Runner not starting
Old Feb 13, 2007 | 06:17 PM
G's 84 Runner's Avatar
I've been working on my 84 runner lately and I am a bit puzzled. It has a 22r, I have replaced the carb recently with a Weber 38. I was experiencing some backfiring and decided to redo my carb gaskets, and replace the intake manifold gasket. Once I got everything back together my ingintion fuse kept popping when I would turn the key to on. I have no answer for is this. I'll try to explain my experimentation a bit now, on the carb, I needed to connect a red wire to the electric choke. I had 3 other wires, 1 white 2 black. The tech folks told me I did not need the white and the black wires that connected to the old O2 senser, so I cut them, and connected the other black wire to a ground spot. I drove around like this for about 6 weeks until the backfiring started. Everything had been working on the truck except I had lost power to my power windows and climate control. I allowed the black wire to float in space during my experimenting and tried cranking the motor. Suddenly, I have power to the windows and climate control!!! However, the engine will not turn over. I poured gas into the carb, and the engine would turn over, so I took the hose off the fuel pump, and i noticed I was not getting any fuel to the carb. All this happening with out that black wire connected to anything. I guessed the fuel pump was bad, I replaced it and got same results. I am assuming I am not getting proper ground on that wire now. Anyone using a weber 38 out there want to show me how they have their carb wired. I am guessing this wire is preventing the carb from sucking in any gas. Any clues, help, or cool guy pictures to follow with my problem here? Thanks in advance.
Team420
Jan 12, 2021 04:57 PM
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
