84 2wd frame same as 4wd?
Old May 12, 2007 | 11:00 PM
Kirby's Avatar
I busted the frame on my 84 toyota, its seriously rusted out, and cracking in new places. I want to do a frame swap and do some other work on it as well, so far the only frame I have found is an 84 2wd frame, I was wondering how this compares the the 4wd frame? Same? totally different?
I've got the specs for the frame but no specification if its for 4wd or all frames
http://www.yankeetoys.org/budbuilt/i...85%20frame.jpg
http://www.yankeetoys.org/Documents/85Frame.gif
Kirby
Old Sep 2, 2007 | 12:39 PM
XtraSlow_XtraCab's Avatar
The 4WD frames are completely boxed in, with four sides to each frame rail. I don't know if the 2WD's are boxed or not... there's really no reason for them to be.
Old Sep 2, 2007 | 10:54 PM
Elvota's Avatar
Check here:
This guy has a lot of specific comparisons and pics between 2WD and 4WD frames as well as components.
Off the top of my head, I believe the arch by the front wheels is higher on a 2WD frame. There may be other differences as well.
Old Sep 2, 2007 | 11:19 PM
DeathCougar's Avatar
Eh, no and no. Not the same. 2wd uses a Torsion bar setup. 4wd uses leaf springs, just as a starting point.
Everything from front to rear is different on the frames.
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
landrunner
Aug 5, 2015 09:18 PM
genuinegemini
Aug 3, 2015 04:56 PM
yourrealdad
Jul 21, 2015 11:13 AM
