5.29 and 4.11 question..
Old Sep 22, 2009 | 11:29 AM
eighty5yota's Avatar
so i have enough money saved up to get a set of 5.29's for the rear of my 85..
my concern is.. sometimes when shifting into reverse, (or a dumb passenger playin with the sticks) sometimes i notice my 4wd light is on..
if i have 529s in back and 411 up front.. it will only blow the xfer case if the hubs are locked too right?
just a question until i can get both sets in..
Old Sep 22, 2009 | 11:47 AM
4Crawler's Avatar
Correct, if front hubs are unlocked, it makes no difference if the ratios are different. To be safe, you could always remove the front drive shaft until you get both gear sets installed.
Old Sep 22, 2009 | 01:34 PM
thats actually not a bad idea.. thanks buddy..
Old Sep 22, 2009 | 02:17 PM
tj884Rdlx's Avatar
Or remove the shift lever
Old Sep 23, 2009 | 03:10 PM
oldgold3vze's Avatar
Harder and you could let dirt into the case. I'd pull the shaft. You'll have to to remove the front diff, anyway.
Old Sep 23, 2009 | 03:32 PM
waskillywabbit's Avatar
Or save your money and do ONE bench gear install labor.
YotaLogic
12
Nov 17, 2015 06:27 AM
toyotasaurus
Sep 24, 2015 03:30 PM
justdifferentials
Sep 5, 2015 06:52 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
coffey50
Jul 28, 2015 10:55 AM
