4in lift = longer drivelines?
Old Feb 17, 2009 | 04:36 PM
twinger1's Avatar
i building a truck from the ground up. engine swap, 5.29 gears, aussi lockers front and rear, custom flat bed, 4in pro comp lift, 2in lift shackles and 35 in tires. im a few weeks from having it done but im wondering if im going to have to lengthen my drivelines with the 4in lift and the 2in lift shackles? anybody done this before and have any input?
Old Feb 17, 2009 | 04:43 PM
olharleyman's Avatar
Not sure on the 1st gen but I did a stage II Pro Comp 4" on my 2nd gen and it worked fine without any drive line lengths but you may have to clearance a bit off your gas tank cover other then that it was a bolt up and play set up for my 2nd gen.
Old Feb 17, 2009 | 04:53 PM
Yodaforce's Avatar
It's fine with a 4". Over 5" and it would be a good idea if you use it offroad and flex it.
Old Feb 17, 2009 | 06:10 PM
4Crawler's Avatar
A lot depends on the type of lift spring. When I put on an off the shelf 3.5" lift spring, I had no issues with drive shaft length. But when I reworked the springs for more flex and especially when I moved the front axle forward about 3/4", I had to get the front shaft lengthened. A drive shaft spacer is always an option if you need to make the shaft just a little longer:
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
Old Feb 17, 2009 | 08:04 PM
85TurboRunner's Avatar
I have that same lift down to the shackles and I have never had issues with the drive lines.
nvdesertrunner
May 11, 2020 08:18 PM
82yodahickman
34
May 16, 2017 01:00 PM
mbomberz1
Aug 8, 2015 06:57 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
bobpat
Aug 1, 2015 09:25 PM
