22re still not running
Old May 23, 2010 | 10:59 PM
broskyo's Avatar
Question 22re still not running
my 85 4runner 22re is still not running I've done the tps and afm tests on 4crawler. I was wondering if anyone knows if the AFM is supposed to make a loud ticking noise(like the air flow gate is opening and closing really fast) when the motor is cranking and almost firing up?
Old May 24, 2010 | 08:38 PM
broskyo's Avatar
EDIT: new question
When I start my 4runner it will fire right up but die in a second, the more I try to start it the less and less it wants to fire up inless it sits for awhile.
Does any one know what this could be? My AMF, fuel pump and TPS work. Could it be the cold start injector?
Old May 25, 2010 | 05:36 PM
dasrunner's Avatar
unplug your air valve underneath the intake, thats what was wrong with mine and it fires up everytime now
Old May 26, 2010 | 03:24 PM
thor99's Avatar
what dasrunner said, same problem to me
Old May 26, 2010 | 11:11 PM
broskyo's Avatar
Just unplug the one connector or both? any pics?
Old May 27, 2010 | 03:49 PM
deserttoy84's Avatar
take off the AFM and shake it. See if it sounds like there is something rattling around. Happened to my friend. the little bolt that holds the little arm that sweeps underneath the cover fell out.
Old May 28, 2010 | 05:30 PM
broskyo's Avatar
OK so now I have a new question.
There is a bunch of pressure building up on the out going side of the fuel filter when I took it off fuel sprayed everywhere and after the fuel pump has ran you can hear the pressure hissing out of the outgoing side of the filter any thought?
Old Jun 1, 2010 | 08:05 AM
its supposed to build and hold pressure. Its fuel injection. sounds more like an AFM problem. If its messed up at all it will either run poorly or not at all.
Old Jun 2, 2010 | 05:46 PM
broskyo's Avatar
I know for sure my AFM is good and understand there needs to be pressure but there seems like the pressure is building up and gas is not getting into the cylinders.
Old Jun 4, 2010 | 11:26 AM
myyota's Avatar
Is there presure between the filter and the fuel rail ?, how old is the fuel filter ?, have you tried replacing the fuel filter to see if that helps ?.
Old Jun 4, 2010 | 06:53 PM
broskyo's Avatar
Yes thats where the pressure is building up after the filter. The fuel filter is pretty new I replaced it about 8months ago
Old Jun 10, 2010 | 01:04 PM
broskyo's Avatar
I took the fuel filter off to see it was clogged or really dirty and it wasnt so I put it back on and now it leaking gas whenever the fuel pump is running.
Old Jun 24, 2010 | 12:03 PM
Staceman1's Avatar
EFI fuse...
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
