22RE Running Help
Old May 11, 2007 | 06:41 PM
corvettelvr73's Avatar
22RE Running Help
My 22re is running weired. It idles ruff and ribrates like crazy. What could be the problem or should i take it to toyota and have them look at it. I know the guy that does all my work and i know his not going to try to scerw me and I even get his disscount. What should I do and what do yall think the problem could be. I hope nothing big
Old May 11, 2007 | 08:07 PM
4runnerx3's Avatar
First thing I would do is spray some carb cleaner on the injector seal areas, then down the intake gasket to rule those out.
Old May 11, 2007 | 08:10 PM
Does that stuff you put in your gas tank work called injector cleaner?
Old May 11, 2007 | 08:32 PM
Bunta Fujiwara's Avatar
just buy some carb cleaner and spray it in there, man... it doesn't matter whether you have a carburetor or not... in fact, "carb" can sometimes mean "carbon" and sometimes mean "carburetor", though I can't imagine you having carbon deposits inside your fuel injection system...
Old May 11, 2007 | 08:35 PM
4runnerx3's Avatar
If you have a leak, it will suck in the carb cleaner and it will level off or rev up for a couple of seconds.
Old May 11, 2007 | 08:38 PM
if that doesn't work, then try this (it should apply whether or not it's running rich):
https://www.yotatech.com/forums/show...t=22RE+running
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
