different idle after test fit isr
Old May 12, 2007 | 06:00 PM
yotasavg's Avatar
i know we've talked about this a million times but.....is it normal that when i tested the ISR pipe and then put everything back the engine started running slower? sould i leave it and adjust the idle when i'm done with the whole project?
also, i didn't have access to a mandrel bender so i used the kind that puts like a dent in the tube inside the bend. will this be a problem for airflow?
thanks for your help guys (maybe a few girls)!
Old May 12, 2007 | 06:30 PM
yotasavg's Avatar
come on now......don't be shy all 8 of you that took the time to probably not even read this!
Old May 12, 2007 | 09:05 PM
bktaco's Avatar
wrong section for your sig truck. other than that, try pulling the cables off the battery to reset the ecu. i dont know if that will help tho.
Sleaker
Aug 26, 2020 06:03 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Jnkml
Jul 6, 2015 01:20 PM
