22RE idle speed adjusting screw
Old Feb 7, 2009 | 04:49 PM
bryonb's Avatar
I'm having problems setting my idle. Truck will only idle smooth if its set around 1000 RPM. I have one turn of the screw left to adjust down the idle. Then the screw bottoms out at 750-800 RPM but its a rough idle.
I've cleaned the throttle body,plenum,cold start injector, air filter,vacume lines. Has a new thermostat. The AMF is clean and the door moves freely.
I just swapped out the old style intake for a 92 intake but this problem was present before the swap. I was hopeing the swap would fix it. Also got rid of the EGR system and blocked it off with the LC Eng. kit. I'm wondering if theres a sensor or something I'm overlooking.
1985 4Runner
Appreciate any help
Old Feb 8, 2009 | 08:58 AM
Brokenstuff's Avatar
Have you checked/messed with the TPS or the air/idle mixture valve?
Old Feb 8, 2009 | 09:48 PM
bryonb's Avatar
I tested and set the TPS to spec. I also adjusted the screw next to the throttle body to smooth out the idle.
Old Feb 21, 2009 | 03:22 AM
pcmentor's Avatar
On my 85 22re, I adj the valves to get it to idle to spec.
smthwsn357
May 1, 2024 07:28 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
