22re fuel injectors
Old Feb 25, 2007 | 04:38 PM
jhksclemm's Avatar
22re fuel injectors
my 85 4x4 fuel injectors are not getting voltage. does anyone have any suggestions on what to check?
Old Feb 25, 2007 | 06:16 PM
titicaca's Avatar
check the grounds...
Old Feb 25, 2007 | 06:38 PM
toyota_mdt_tech's Avatar
Yes, EFI main relay. Does the check engine light come on whent eh key is turned on, engine off? If not, it needs to. Also, is the injector resistor plugged in? Little aluminum heat sink just inside pass fender.
Old Feb 25, 2007 | 07:08 PM
4runnerx3's Avatar
Old Feb 25, 2007 | 07:48 PM
jhksclemm's Avatar
Yes, the EFI main relay is clicking when I turn the key on. Yes the check engine light comes on when the key is turned on, engine off. The injector resistor is plugged in. I have a manual should I check all of the resistance readings?
Old Feb 26, 2007 | 11:52 AM
jhksclemm's Avatar
Voltage to the circuit opening relay is only at 7 volts. What could be cuasing that?
Old Feb 26, 2007 | 04:57 PM
The circuit opening relay isnt an issue on this. Its only job is to turn on the fuel pump. As for injectors, can you put a noid light across the terminals of an injector connector, crank and see if you get a pulse?
Did someone have the engine out and forget to hook up a wire harness ground to the intake manifold? See this often. Did you do an engine swap recently? Did you change injectors? There is 2 different types, ie high and lo resistance ones.
Old Feb 27, 2007 | 08:23 PM
jhksclemm's Avatar
Can you tell me how to check the igniter? And should i get voltage at the igf terminal on the ecu while turning the engine over? I just rebuilt the motor but this problem was there before I rebuilt. Thanks.
Old Feb 28, 2007 | 12:33 PM
jhksclemm's Avatar
22re fuel injectors
Ok, here's where I stand at this point.
The engine will try to fire with starting fluid.
I have 12v at #10 and #20 on the ecu. and is fluctuating while turning engine over.
Checked continuity between 10/20 and the injector plug. Checked ok.
E01 and E02 showing to be grounded.
12v from the resistor.
12v at the injector plug with key on.
Signal generator in the distributer ohm'ed ok and set gap to .010.
Getting 1.09 v at IGT on the ecu while turning engine over.
Getting .75v at IGF on the ecu while turning engine over.
Have 12v at NE on the ecu with key on.
I am getting fuel to the rail.
Hooked up a niod light the the injector plug, and am getting no signal.
will this information help anyone figure this out?
Old Feb 28, 2007 | 01:19 PM
jhksclemm's Avatar
22re fuel injectors
I also have 2 plugs that I have no idea where they go and one broke wire.
the plugs have ends on them like the fuel injectors do (with the wire clip) one has a blue and white/black stripe wires coming from it and the other has a black/yellow stripe and black wires coming from it.
The broke wire is light green with a red stripe.
Can anyone identify these?
Old Mar 1, 2007 | 01:51 PM
jhksclemm's Avatar
22re fuel injectors
Please help. I really need to get this up and going.
Old Oct 21, 2011 | 12:48 PM
my 75 toyota's Avatar
no flow
#10 an #20 are the ground signals to the injectors as they are fired via ground off ecm.
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
steve miller
Oct 10, 2015 01:40 AM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
