22re efi high idle
Old Apr 2, 2015 | 07:03 AM
thefishguy77's Avatar
Ok just reread the thread. When you set the timing you jumped the diagnostic ports correct?
Have you gone trough and looked for bared wires. My 85 runner had a random idle problem when I got it. Dealership told the PO it needed a new motor. I found a bared wire on the AC cooler sensor. (The one on top of the thermostats housing). That seemed to fix the problem. Gently inspect all the connections you can. Remove clean and reattach all your ground. Engine bay and cab. Put a dab of dielectric grease on each one.
Might be something as simple as off a tooth in the distributor but checking that also means the jumping the diagnostic port to check timing. It is not a carb. The FI takes a little to figure out. But this FI is one of the better ones I have experienced.
Also take a can of starter fluid and check for vacuum leaks. With the motor running spray around the intake. If you haven't already. Have you checked the bottom of the rubber hose that connect the vafm to the throttle body? Those can crack on the bottom and you won't see it time you rip it off to fix something.
Good luck keep us posted.
Old Apr 2, 2015 | 02:05 PM
theduck21's Avatar
Sprayed carb cleaner around and found that the fuel line that bolts into the drivers side of the intake had a slight bend in it and when the carb cleaner hit the rpms would jump to 2000 and hang there. Unbolted it, put a new gasket on and a little high temp gasket maker. I wanted to bend the plate straight but was afraid of ˟˟˟˟˟ing it up because I seem to be good at that haha.Waiting on the rtv to cure and ill start it up and try again.
Old Apr 2, 2015 | 02:40 PM
Yhatzee.
Let's hope that's it. Little things like that will drive you crazy chasing other legitimate causes of the same symptom.
Old Apr 2, 2015 | 07:21 PM
theduck21's Avatar
It changed just a little bit, messed with the tps a little. Turned it all the way counter clockwise and the idle slowed down and its running great! Hopefully it won't change its mind tomorrow
Old Apr 3, 2015 | 06:19 AM
  #25
When you say turned it clockwise. Are you talking about the TPS? If so unless that made the TPS test properly with the multimeter that probably will not solve the problem.
Old Apr 5, 2015 | 08:58 AM
  #26
theduck21's Avatar
Yes the tps. It idles fine and the check engine light went off.
redneck17
Oct 29, 2015 09:09 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
Sandman
Jul 14, 2015 12:36 PM
ZONAYODA
Jul 13, 2015 07:17 PM
